Introducción
Sometimes we may find the stickers on our cars unwanted. In this case, we would like to remove the stickers without damaging our beautiful car paint. In this guide, I will show you how to remove stickers from a car properly.
Qué necesitas
First of all, find the area where the sticker is. In my case, it is on the car body near the fuel tank.
Herramienta utilizada en este paso:Microfiber Cleaning Cloths$3.99
Next, wipe the area thoroughly with a microfiber cleaning cloth. Skip this step if you're using Goo Gone.
Herramienta utilizada en este paso:Plastic Cards$2.99
Use a plastic card and try to scrape the sticker from the edges.
If it doesn't work, try to repeat step 4 and then try again.
Finally, if there is any residue, heat the residue with the hairdryer and scrape it off with a plastic card or razor blade (depending on where the sticker is). Using Goo Gone makes removing any residue easy.
After removing all stickers and residue, use some detailing spray or cleaning spray to clean the area again and you are all set!
After these steps, you should have a clean surface without any residues!
