Saltar al contenido principal
How to Remove Rust from a Gardening Shovel
Qué necesitas
  1. How to Remove Rust from a Gardening Shovel, How to Remove Rust from a Gardening Shovel: paso 1, imagen 1 de 1
    • Fill a large container with water.
  2. How to Remove Rust from a Gardening Shovel: paso 2, imagen 1 de 1
    • Add an ample amount of distilled white vinegar.
  3. How to Remove Rust from a Gardening Shovel: paso 3, imagen 1 de 1
    • Soak the shovel for at least 10 minutes, but ideally for 24 hours.
  4. How to Remove Rust from a Gardening Shovel: paso 4, imagen 1 de 1
    • Scrub the shovel with a scrub brush.
    • Scrub with a tooth brush.
    • Scrub with a Brillo pad.
  5. How to Remove Rust from a Gardening Shovel: paso 5, imagen 1 de 1
    • Refill the large container with fresh water.
  6. How to Remove Rust from a Gardening Shovel: paso 6, imagen 1 de 1
    • Add 1-2 cups of baking soda.
  7. How to Remove Rust from a Gardening Shovel: paso 7, imagen 1 de 1
    • Soak the shovel for 15 minutes.
  8. How to Remove Rust from a Gardening Shovel: paso 8, imagen 1 de 1
    • Rinse the shovel.
  9. How to Remove Rust from a Gardening Shovel: paso 9, imagen 1 de 1
    • Dry the shovel completely.
  10. How to Remove Rust from a Gardening Shovel: paso 10, imagen 1 de 1
    • Oil the shovel with coconut oil.
Conclusión
Repeat process until rust is completely removed.
Brigette B
Miembro Desde 09/22/23
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 84
