Saltar al contenido principal
How to Recharge the A/C in a 2012 Hyundai Tucson
Qué necesitas
  1. How to Recharge the A/C in a 2012 Hyundai Tucson, How to Recharge the A/C in a 2012 Hyundai Tucson: paso 1, imagen 1 de 1
    • Enter the car and turn on the coldest and most powerful A/C you can.
    • Make sure the A/C button is on.
  2. How to Recharge the A/C in a 2012 Hyundai Tucson: paso 2, imagen 1 de 1
    • Pop the hood open on the left side of the driver’s seat.
    • Secure the hood with the pole brace found on the left side of the engine near the low pressure fill port.
  3. How to Recharge the A/C in a 2012 Hyundai Tucson: paso 3, imagen 1 de 2 How to Recharge the A/C in a 2012 Hyundai Tucson: paso 3, imagen 2 de 2
    • Screw the hose to the top of the R134a refrigerant. Screw to the right until failure. Remove low pressure fill cap.
  4. How to Recharge the A/C in a 2012 Hyundai Tucson: paso 4, imagen 1 de 2 How to Recharge the A/C in a 2012 Hyundai Tucson: paso 4, imagen 2 de 2
    • With the A/C blowing cold and strong, attach the adapter at the end of the hose to the low pressure fill port.
    • Once the adapter is securely fastened, pull and hold the trigger with the bottle upside down.
    • You will begin to feel the bottle get cold. This is the refrigerant becoming activated.
Linea de Meta
Una persona más ha completado esta guía.
Micah B
Miembro Desde 03/21/23
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 43
Ultimos 30 días: 178
Todo El Tiempo: 1,407
