Saltar al contenido principal
How to Patch a Tear in Vinyl Furniture
Qué necesitas
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: paso 1, imagen 1 de 1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: paso 2, imagen 1 de 1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: paso 3, imagen 1 de 2 How to Patch a Tear in Vinyl Furniture: paso 3, imagen 2 de 2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: paso 4, imagen 1 de 2 How to Patch a Tear in Vinyl Furniture: paso 4, imagen 2 de 2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: paso 5, imagen 1 de 1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: paso 6, imagen 1 de 2 How to Patch a Tear in Vinyl Furniture: paso 6, imagen 2 de 2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Conclusión
Once the adhesive is dry, the furniture is ready for use!
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 54
Ultimos 30 días: 369
Todo El Tiempo: 24,933
