Saltar al contenido principal
How to Install LED License Plate Lights
Qué necesitas
  1. How to Install LED License Plate Lights, Prep work: paso 1, imagen 1 de 1
    • You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
  2. How to Install LED License Plate Lights, Removing the stock bulb: paso 2, imagen 1 de 3 How to Install LED License Plate Lights, Removing the stock bulb: paso 2, imagen 2 de 3 How to Install LED License Plate Lights, Removing the stock bulb: paso 2, imagen 3 de 3
    • Pull out the license plate lamp assembly and remove the stock license plate bulb.
  3. How to Install LED License Plate Lights, Installing the LED license plate bulb: paso 3, imagen 1 de 2 How to Install LED License Plate Lights, Installing the LED license plate bulb: paso 3, imagen 2 de 2
    • Install back the new LED license plate bulb.
    • Test to make sure the LED bulb works.
  4. How to Install LED License Plate Lights, Putting the license plate assembly back: paso 4, imagen 1 de 2 How to Install LED License Plate Lights, Putting the license plate assembly back: paso 4, imagen 2 de 2
    • Put the license plate assembly back and repeat on the other side.
  5. How to Install LED License Plate Lights, Enjoy: paso 5, imagen 1 de 1
    • Once everything works, you can enjoy your new LED license plate look.
Conclusión
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
6 personas más completaron esta guía.
Eric Wu
Miembro Desde 01/21/15
3,357 Reputación
23 Guías creadas
2 comentarios
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
David Spalding - Contestar
Good information!
limoh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 79
Todo El Tiempo: 14,898
