Saltar al contenido principal
How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
Qué necesitas
  1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 1, imagen 1 de 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 1, imagen 2 de 2
    • Lean back the chair and extend the leg rest completely.
  2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 2, imagen 1 de 1
    • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
  3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 3, imagen 1 de 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 3, imagen 2 de 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 3, imagen 3 de 3
    • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
  4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 4, imagen 1 de 1
    • Slide the leg rest out of the base.
  5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 5, imagen 1 de 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 5, imagen 2 de 2
    • Place the leg rest on a flat surface.
    • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
  6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 6, imagen 1 de 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 6, imagen 2 de 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 6, imagen 3 de 3
    • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
    • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
  7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 7, imagen 1 de 1
    • Slide the leg rest back into the base.
  8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 8, imagen 1 de 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: paso 8, imagen 2 de 2
    • Screw the 3 mm blocker screw back in.
    • Flip your chair back up and enjoy your sturdy leg rest!
Conclusión
Anoop Shahi
Miembro Desde 01/17/21
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 414
