Saltar al contenido principal
How to Fix a Stretched or Loose Canvas
Qué necesitas
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: paso 1, imagen 1 de 2 How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: paso 1, imagen 2 de 2
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: paso 2, imagen 1 de 3 How to Fix a Stretched or Loose Canvas: paso 2, imagen 2 de 3 How to Fix a Stretched or Loose Canvas: paso 2, imagen 3 de 3
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: paso 3, imagen 1 de 2 How to Fix a Stretched or Loose Canvas: paso 3, imagen 2 de 2
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: paso 4, imagen 1 de 3 How to Fix a Stretched or Loose Canvas: paso 4, imagen 2 de 3 How to Fix a Stretched or Loose Canvas: paso 4, imagen 3 de 3
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: paso 5, imagen 1 de 2 How to Fix a Stretched or Loose Canvas: paso 5, imagen 2 de 2
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: paso 6, imagen 1 de 3 How to Fix a Stretched or Loose Canvas: paso 6, imagen 2 de 3 How to Fix a Stretched or Loose Canvas: paso 6, imagen 3 de 3
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: paso 7, imagen 1 de 2 How to Fix a Stretched or Loose Canvas: paso 7, imagen 2 de 2
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
Conclusión
If it does not work, you should follow another guide where plaster is used in the canvas.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 37
Ultimos 30 días: 105
Todo El Tiempo: 1,422
