Saltar al contenido principal
How to Fix a Papasan Chair Base
Qué necesitas
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: paso 1, imagen 1 de 2 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: paso 1, imagen 2 de 2
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: paso 2, imagen 1 de 1
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: paso 3, imagen 1 de 2 How to Fix a Papasan Chair Base: paso 3, imagen 2 de 2
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: paso 4, imagen 1 de 1
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: paso 5, imagen 1 de 1
    • Screw the circular base and upper to the vertical supports that have become disconnected.
  6. How to Fix a Papasan Chair Base: paso 6, imagen 1 de 1
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: paso 7, imagen 1 de 2 How to Fix a Papasan Chair Base: paso 7, imagen 2 de 2
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Conclusión
Following these steps will restore your papasan chair to working order.
6 personas más completaron esta guía.
3 comentarios
What screw you used? Screw dimensions?
Lourdes Diaz - Contestar
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 87
Ultimos 30 días: 365
Todo El Tiempo: 17,641
