Saltar al contenido principal
How to Fix a Misaligned Desk Drawer
Qué necesitas
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: paso 1, imagen 1 de 2 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: paso 1, imagen 2 de 2
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: paso 2, imagen 1 de 2 How to Fix a Misaligned Desk Drawer: paso 2, imagen 2 de 2
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: paso 3, imagen 1 de 2 How to Fix a Misaligned Desk Drawer: paso 3, imagen 2 de 2
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: paso 4, imagen 1 de 1
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: paso 5, imagen 1 de 1
    • Enjoy your fully functioning drawer!
Conclusión
Dante Mazzanti
Miembro Desde 02/23/15
598 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 54
Todo El Tiempo: 16,016
