Saltar al contenido principal
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
Qué necesitas
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 1, imagen 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 1, imagen 2 de 2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 2, imagen 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 2, imagen 2 de 2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 3, imagen 1 de 1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 4, imagen 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 4, imagen 2 de 2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 5, imagen 1 de 1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 6, imagen 1 de 1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 7, imagen 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: paso 7, imagen 2 de 2
    • Tighten the two screws using a JIS #00 screwdriver.
Conclusión
5 personas más completaron esta guía.
Un comentario
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 42
Todo El Tiempo: 1,114
