Saltar al contenido principal
How to Fix a Crooked Cabinet
Qué necesitas
  1. How to Fix a Crooked Cabinet, Examine the Issue: paso 1, imagen 1 de 3 How to Fix a Crooked Cabinet, Examine the Issue: paso 1, imagen 2 de 3 How to Fix a Crooked Cabinet, Examine the Issue: paso 1, imagen 3 de 3
    • Examine which door needs to be adjusted and to what extent.
  2. How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: paso 2, imagen 1 de 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: paso 2, imagen 2 de 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: paso 2, imagen 3 de 3
    • Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
    • Tighten the screws to adjust accordingly.
  3. How to Fix a Crooked Cabinet, Repeat with the Top Screws: paso 3, imagen 1 de 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: paso 3, imagen 2 de 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: paso 3, imagen 3 de 3
    • Repeat Step 2 with the screws at the top.
  4. How to Fix a Crooked Cabinet, Adjust to Gap: paso 4, imagen 1 de 1
    • The gap should be even from top to bottom, ensure that it is and hold the cabinet in place to adjust if it is not.
  5. How to Fix a Crooked Cabinet, Feel Accomplished: paso 5, imagen 1 de 2 How to Fix a Crooked Cabinet, Feel Accomplished: paso 5, imagen 2 de 2
    • You've done it! As long as the gap is even, your results should be just like this.
    • Great job!
Linea de Meta
Una persona más ha completado esta guía.
Elmore Smith
Miembro Desde 11/20/22
148 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 99
Todo El Tiempo: 945
