Saltar al contenido principal
How to Fix Anything
  1. How to Fix Anything, Define the Problem: paso 1, imagen 1 de 1
    • Try to describe what your device is doing and what instead you expect it to do.
    • If it is not obvious, check if the behaviour is actually a problem or not.
    • Pro tip: even if this is the intended behaviour, you are entitled to modify it, if you like. Just it's not "fixing" anymore: that's hacking!
    • Did you forget to put the plug in the socket? Did you check the battery? Is the light bulb burn out?
    • In Europe, everything has two years of warranty by law. Do not give up your rights!
    • There is a very good chance that you will find something useful with a little search online.
  2. How to Fix Anything, Talk to your Community: paso 6, imagen 1 de 1
    • Speak with friends, family or collegues. Even if they don't know anything, speaking helps a lot the reasoning.
    • Speak to a rubber duck
  3. How to Fix Anything, Mind the safety.: paso 7, imagen 1 de 1
    • Take a minute to think if there is anything that could be a safety hazard.
    • Check the user manual and the package, if available, and the device itself for any danger label.
Conclusión
You are now ready to repair your stuff!
8 personas más completaron esta guía.
Davide
Miembro Desde 07/15/16
447 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 31
Ultimos 30 días: 151
Todo El Tiempo: 1,764
