Saltar al contenido principal
How to Check a Car's Tire Pressure
Qué necesitas
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: paso 1, imagen 1 de 2 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: paso 1, imagen 2 de 2
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
  2. How to Check a Car's Tire Pressure: paso 2, imagen 1 de 3 How to Check a Car's Tire Pressure: paso 2, imagen 2 de 3 How to Check a Car's Tire Pressure: paso 2, imagen 3 de 3
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
  3. How to Check a Car's Tire Pressure: paso 3, imagen 1 de 2 How to Check a Car's Tire Pressure: paso 3, imagen 2 de 2
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
  4. How to Check a Car's Tire Pressure: paso 4, imagen 1 de 2 How to Check a Car's Tire Pressure: paso 4, imagen 2 de 2
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
Linea de Meta
2 personas más completaron esta guía.
Craig Lloyd
Miembro Desde 02/10/16
35,543 Reputación
82 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 64
Todo El Tiempo: 1,919
