Saltar al contenido principal
How To Start Remote Viewfinder on Samsung WB150F
Qué necesitas
  1. How To Start Remote Viewfinder on Samsung WB150F, Power on the device: paso 1, imagen 1 de 2 How To Start Remote Viewfinder on Samsung WB150F, Power on the device: paso 1, imagen 2 de 2
    • Turn on the device by pressing the button thats labeled POWER on the top.
  2. How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: paso 2, imagen 1 de 2 How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: paso 2, imagen 2 de 2
    • Look at the wheel at the top
    • Scroll until the dot is at Wi-Fi
  3. How To Start Remote Viewfinder on Samsung WB150F: paso 3, imagen 1 de 3 How To Start Remote Viewfinder on Samsung WB150F: paso 3, imagen 2 de 3 How To Start Remote Viewfinder on Samsung WB150F: paso 3, imagen 3 de 3
    • Navigate using the Navigation wheel
    • Navigate until the blue glowing square is on Remote Viewfinder
    • Press OK
  4. How To Start Remote Viewfinder on Samsung WB150F, Setting Up: paso 4, imagen 1 de 1
    • If everything done correctly, You will be on this screen, Time to install the viewfinder app.
  5. How To Start Remote Viewfinder on Samsung WB150F, Finding the app: paso 5, imagen 1 de 1
    • Search up Remote ViewFinder on App Store/Play Store
  6. How To Start Remote Viewfinder on Samsung WB150F, Downloading the app: paso 6, imagen 1 de 1
    • When you found the app, Press the download button
    • If it is a cloud, It means it was installed before, You will not need a password to download it.
    • The App Is pretty outdated, I suggest using iOS 4-10, It wont work on newer iOS
    • An iPhone 5c or an iPad 4 works well.
  7. How To Start Remote Viewfinder on Samsung WB150F, Connecting: paso 7, imagen 1 de 2 How To Start Remote Viewfinder on Samsung WB150F, Connecting: paso 7, imagen 2 de 2
    • Open up settings and go to the Wifi Tab
    • Connect your device to the cameras wifi.
    • The Wifi name should be the same as on the camera.
  8. How To Start Remote Viewfinder on Samsung WB150F, Starting the application: paso 8, imagen 1 de 1
    • Launch Remote Viewfinder on your device
  9. How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: paso 9, imagen 1 de 2 How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: paso 9, imagen 2 de 2
    • Wait until its connected.
    • If you see the screen of your camera Your camera is connected (see step 10 for controls)
  10. How To Start Remote Viewfinder on Samsung WB150F, Controls: paso 10, imagen 1 de 1
    • Flash
    • Timer
    • Photo Size
    • Zoom
    • Shutter Button
    • Camera View
    • Tap the camera view to hide/show the menu.
Conclusión
Close the app, to disconnect your camera from the app
Artem Ivat
Miembro Desde 02/05/20
2,772 Reputación
12 Guías creadas
Equipo
Kid fixers Miembro de Kid fixers
Community
166 Miembros
302 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 44
Todo El Tiempo: 1,010
