Saltar al contenido principal
How To Patch a Hole in Umbrella Fabric
Qué necesitas
  1. How To Patch a Hole in Umbrella Fabric, Fabric: paso 1, imagen 1 de 1
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: paso 2, imagen 1 de 1
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: paso 3, imagen 1 de 1
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: paso 4, imagen 1 de 1
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: paso 5, imagen 1 de 1
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: paso 6, imagen 1 de 1
    • Apply your patch squarely over the torn fabric.
Conclusión
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
Miembro Desde 10/04/20
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 132
Ultimos 30 días: 475
Todo El Tiempo: 12,933
