Saltar al contenido principal
How To Hem Pants With Double-Sided Fabric Tape
Qué necesitas
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: paso 1, imagen 1 de 1
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: paso 2, imagen 1 de 1
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: paso 3, imagen 1 de 1
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: paso 4, imagen 1 de 1
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: paso 5, imagen 1 de 1
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: paso 6, imagen 1 de 1
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: paso 7, imagen 1 de 1
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: paso 8, imagen 1 de 1
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: paso 9, imagen 1 de 1
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: paso 10, imagen 1 de 1
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: paso 11, imagen 1 de 1
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: paso 12, imagen 1 de 1
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
Conclusión
You don't need a sewing machine to hem a pair of overly long pants.
Allison
Miembro Desde 10/07/23
205 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 17
Ultimos 30 días: 58
Todo El Tiempo: 210
