Saltar al contenido principal
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
Qué necesitas
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: paso 1, imagen 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 2, imagen 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 3, imagen 1 de 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 3, imagen 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 4, imagen 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: paso 5, imagen 1 de 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: paso 5, imagen 2 de 2
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 6, imagen 1 de 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 6, imagen 2 de 2
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 7, imagen 1 de 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 7, imagen 2 de 2
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 8, imagen 1 de 1
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 9, imagen 1 de 3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 9, imagen 2 de 3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 9, imagen 3 de 3
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 10, imagen 1 de 1
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 11, imagen 1 de 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 11, imagen 2 de 2
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 12, imagen 1 de 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 12, imagen 2 de 2
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: paso 13, imagen 1 de 1
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
Conclusión
5 personas más completaron esta guía.
Aaron Teh
Miembro Desde 10/08/18
442 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G6, White Fall 2018 Miembro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Miembros
7 Guías creadas
Un comentario
where can I get the replacement parts?
Rob Sayles - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 20
Ultimos 30 días: 109
Todo El Tiempo: 4,923
