Saltar al contenido principal
Holley 4 Barrel Carburetor Gasket Replacement
Qué necesitas
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: paso 1, imagen 1 de 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: paso 1, imagen 2 de 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: paso 1, imagen 3 de 3
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: paso 2, imagen 1 de 1
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: paso 3, imagen 1 de 1
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: paso 4, imagen 1 de 1
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: paso 5, imagen 1 de 1
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: paso 6, imagen 1 de 2 Holley 4 Barrel Carburetor Gasket Replacement: paso 6, imagen 2 de 2
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: paso 7, imagen 1 de 1
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: paso 8, imagen 1 de 1
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: paso 9, imagen 1 de 2 Holley 4 Barrel Carburetor Gasket Replacement: paso 9, imagen 2 de 2
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 57
Todo El Tiempo: 4,396
