Saltar al contenido principal
Handspring Visor Edge Battery Replacement
Qué necesitas
  1. Handspring Visor Edge Battery Replacement, Flip Cover: paso 1, imagen 1 de 2 Handspring Visor Edge Battery Replacement, Flip Cover: paso 1, imagen 2 de 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Battery Replacement, Back Panel: paso 2, imagen 1 de 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Battery Replacement: paso 3, imagen 1 de 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Battery Replacement: paso 4, imagen 1 de 2 Handspring Visor Edge Battery Replacement: paso 4, imagen 2 de 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Battery Replacement: paso 5, imagen 1 de 2 Handspring Visor Edge Battery Replacement: paso 5, imagen 2 de 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Battery Replacement: paso 6, imagen 1 de 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Battery Replacement, Battery: paso 7, imagen 1 de 1
    • Gently pull off the front cover.
  8. Handspring Visor Edge Battery Replacement: paso 8, imagen 1 de 2 Handspring Visor Edge Battery Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Gently use your finger or tweezers to push the brown lock away from the side of the circuit board that is holding the ribbon cable.
    • Remove the ribbon cable with tweezers.
  9. Handspring Visor Edge Battery Replacement: paso 9, imagen 1 de 1
    • Using the tweezers, pull back the ribbon cable on the top of the device.
    • Pull at the white part of the ribbon to avoid tearing.
  10. Handspring Visor Edge Battery Replacement: paso 10, imagen 1 de 1
    • Using the same technique as with the other ribbons, locate and disconnect the ribbon cable above the battery pack.
  11. Handspring Visor Edge Battery Replacement: paso 11, imagen 1 de 1
    • All the ribbon cables should be disconnected from the mother board.
    • Remove the four 3.6 mm Phillips #00 screws located at each corner of the device.
  12. Handspring Visor Edge Battery Replacement: paso 12, imagen 1 de 2 Handspring Visor Edge Battery Replacement: paso 12, imagen 2 de 2
    • Carefully separate the circuit board and the screen. (Be careful of soldered wires when separating)
    • Be careful not to break the soldered wires that connects the circuit board to the battery pack.
    • Disconnect the wire that connects the battery pack to the motherboard using tweezers.
  13. Handspring Visor Edge Battery Replacement: paso 13, imagen 1 de 2 Handspring Visor Edge Battery Replacement: paso 13, imagen 2 de 2
    • Wedge the spudger under the battery to pry it apart from the adhesive.
Conclusión
Equipo
Cal Poly, Team 11-28, Maness Winter 2011 Miembro de Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 3,168
