Saltar al contenido principal
GOTRAX GMAX Ultra Brake Caliper Replacement
Qué necesitas
  1. GOTRAX GMAX Ultra Brake Caliper Replacement, Brake Caliper: paso 1, imagen 1 de 2 GOTRAX GMAX Ultra Brake Caliper Replacement, Brake Caliper: paso 1, imagen 2 de 2
    • Use the 5mm hex key to remove the 16mm screw holding the brake cable in place.
    • This will release the brake cable and metal clamp.
  2. GOTRAX GMAX Ultra Brake Caliper Replacement: paso 2, imagen 1 de 1
    • Next, use the 4 mm Hex key to remove the 14 mm screw on the side of the caliper that holds the housing to the brake pads.
    • As soon as the screw is loosened, a spring will release the tension of the caliper.
  3. GOTRAX GMAX Ultra Brake Caliper Replacement: paso 3, imagen 1 de 2 GOTRAX GMAX Ultra Brake Caliper Replacement: paso 3, imagen 2 de 2
    • Use the 4 mm Hex key to remove two 22 mm screws that hold the caliper to the scooter body.
    • Carefully remove these to avoid scratching the wheel cover with the hex key.
  4. GOTRAX GMAX Ultra Brake Caliper Replacement: paso 4, imagen 1 de 1
    • With the two screws removed, the caliper is now free from the scooter.
    • Loosen the screw and washer that holds the brake cable in place.
  5. GOTRAX GMAX Ultra Brake Caliper Replacement: paso 5, imagen 1 de 2 GOTRAX GMAX Ultra Brake Caliper Replacement: paso 5, imagen 2 de 2
    • This screw and washer stays on the scooter so it only needs to be loosened enough to free the cable.
    • No tools are required to loosen this, but you can always use something like pliers if it was screwed too tight.
  6. GOTRAX GMAX Ultra Brake Caliper Replacement: paso 6, imagen 1 de 1
    • Remove the brake caliper.
Conclusión
To reassemble your device, simply follow these instructions in reverse order. You may have to adjust the caliper and brake cable in order for the disc to spin smoothly.
Una persona más ha completado esta guía.
Jeremy Goldberg
Miembro Desde 01/11/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 13
Ultimos 30 días: 61
Todo El Tiempo: 1,452
