Saltar al contenido principal
Foldable Grocery Cart Wheels Replacement
Qué necesitas
  1. Foldable Grocery Cart Wheels Replacement, Wheels: paso 1, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement, Wheels: paso 1, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement, Wheels: paso 1, imagen 3 de 3
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
  2. Foldable Grocery Cart Wheels Replacement: paso 2, imagen 1 de 2 Foldable Grocery Cart Wheels Replacement: paso 2, imagen 2 de 2
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: paso 3, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 3, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 3, imagen 3 de 3
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: paso 4, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 4, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 4, imagen 3 de 3
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: paso 5, imagen 1 de 2 Foldable Grocery Cart Wheels Replacement: paso 5, imagen 2 de 2
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
  6. Foldable Grocery Cart Wheels Replacement: paso 6, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 6, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 6, imagen 3 de 3
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: paso 7, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 7, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 7, imagen 3 de 3
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: paso 8, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 8, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 8, imagen 3 de 3
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: paso 9, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 9, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 9, imagen 3 de 3
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
  10. Foldable Grocery Cart Wheels Replacement: paso 10, imagen 1 de 3 Foldable Grocery Cart Wheels Replacement: paso 10, imagen 2 de 3 Foldable Grocery Cart Wheels Replacement: paso 10, imagen 3 de 3
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
Conclusión
2 personas más completaron esta guía.
Saba Aafreen
Miembro Desde 06/30/21
232 Reputación
1 Guía escrita
Un comentario
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 66
Ultimos 30 días: 306
Todo El Tiempo: 8,509
