Saltar al contenido principal
Fix: makecab.exe runs for 5-10 minutes after every startup
  1. Fix: makecab.exe runs for 5-10 minutes after every startup, Find CBS log files folder: paso 1, imagen 1 de 1
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: paso 2, imagen 1 de 2 Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: paso 2, imagen 2 de 2
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
Linea de Meta
4 personas más completaron esta guía.
Somnic
Miembro Desde 07/13/18
195 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 868
