Saltar al contenido principal
Felco Gartenschere - Pruners Disassembly
Qué necesitas
  1. Felco Gartenschere - Pruners Disassembly, Various types available: paso 1, imagen 1 de 1
    • There are several types - e.g. also for left-handers, here a Felco Nr 4 is shown.
  2. Felco Gartenschere - Pruners Disassembly, Release mother: paso 2, imagen 1 de 1
    • First, the upper nut SW 13 is released, then the scissors is turned over.
    • The spring can be easily removed.
  3. Felco Gartenschere - Pruners Disassembly, Release screw from below: paso 3, imagen 1 de 1
    • Now the hinge screw can be unscrewed. Here SW 14 is used Next to it lies the spring and the lock nut.
    • Now the scissors can be completely disassembled.
    • The blade is pinned with three bolts in the handle half and usually dissolves easily.
  4. Felco Gartenschere - Pruners Disassembly, The items: paso 4, imagen 1 de 1
    • The scissors are disassembled. We see the pivot nut, the hinge screw, the spring, the two handles and the blade.
    • The blade is ground on one side. Sharpen the beveled edge with about 15 degrees, only deburr the straight edge with a maximum of 5 degrees.
    • The parts should be free from rust and freshly oiled or greased.
Conclusión
Repeat the steps in order to reassemble your device.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
VauWeh
Miembro Desde 10/19/15
205,815 Reputación
252 Guías creadas
Equipo
Repair is War on Entropy Miembro de Repair is War on Entropy
Community
25 Miembros
1,158 Guías creadas
2 comentarios
Does the fixed bolt need Locktight or thread locker applied to its thread to stop it coming loose in operation?
Nicholas Little - Contestar
I did not use a thread locker and ist works until today.
VauWeh -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 38
Todo El Tiempo: 2,192
