Saltar al contenido principal
Fast Fix Bed boards Replacement
Qué necesitas
  1. Fast Fix Bed boards Replacement, Bed boards: paso 1, imagen 1 de 2 Fast Fix Bed boards Replacement, Bed boards: paso 1, imagen 2 de 2
    • Step 1: Removing the matress
    • Gently remove the matress from the bed.
  2. Fast Fix Bed boards Replacement: paso 2, imagen 1 de 1
    • Step 2: Removing the box spring.
    • Remove the box spring from the frame.
  3. Fast Fix Bed boards Replacement: paso 3, imagen 1 de 1
    • Step 3: Removing old boards with screwdriver.
    • Remove the old boards with the screwdriver.
  4. Fast Fix Bed boards Replacement: paso 4, imagen 1 de 1
    • Step 4: Measure old boards with measure tape
    • Measure the old boards with the measure tape and write the measures down.
  5. Fast Fix Bed boards Replacement: paso 5, imagen 1 de 1
    • Step 5: Getting some wooden boards with 2x2 measures.
    • Get some wooden boards with 2x2 (width) measures and with the long that you already measured.
  6. Fast Fix Bed boards Replacement: paso 6, imagen 1 de 2 Fast Fix Bed boards Replacement: paso 6, imagen 2 de 2
    • Step 6: Putting your replacing boards with screws.
    • Put your replacing boards with screws in the same spot as the the others were.
  7. Fast Fix Bed boards Replacement: paso 7, imagen 1 de 3 Fast Fix Bed boards Replacement: paso 7, imagen 2 de 3 Fast Fix Bed boards Replacement: paso 7, imagen 3 de 3
    • Step 7: Putting your box spring ad matress back
    • Put your box spring and matress back and you are done.
Conclusión
To assemble your bed, follow these instructions in order and you will do fine.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
en es
0%
¡ Kiara De Jesus nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 54
Todo El Tiempo: 887
