Saltar al contenido principal
Disassembling Sony Cyber-shot DSC-W230 Exterior Case
Qué necesitas
  1. Disassembling Sony Cyber-shot DSC-W230 Exterior Case, Case: paso 1, imagen 1 de 1
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Exterior Case: paso 2, imagen 1 de 2 Disassembling Sony Cyber-shot DSC-W230 Exterior Case: paso 2, imagen 2 de 2
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Exterior Case: paso 3, imagen 1 de 3 Disassembling Sony Cyber-shot DSC-W230 Exterior Case: paso 3, imagen 2 de 3 Disassembling Sony Cyber-shot DSC-W230 Exterior Case: paso 3, imagen 3 de 3
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
Conclusión
4 personas más completaron esta guía.
Alex
Miembro Desde 03/09/12
190 Reputación
3 Guías creadas
Equipo
Clemson, Team 2-3, Benson Spring 2012 Miembro de Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
3 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 1,520
