Saltar al contenido principal
Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover
Qué necesitas
  1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: paso 1, imagen 1 de 2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: paso 1, imagen 2 de 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 2, imagen 1 de 1
    • Remove the battery from the door that you opened in the previous step.
  3. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 1 de 3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 2 de 3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 3 de 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 4, imagen 1 de 2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 4, imagen 2 de 2
    • Use hands to gently pry the front casing away from the camera.
Conclusión
Una persona más ha completado esta guía.
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,569
