Saltar al contenido principal
Disassembling Sony Clie PEG-SL10
Qué necesitas
  1. Disassembling Sony Clie PEG-SL10, Disassembling Sony Clie PEG-SL10: paso 1, imagen 1 de 1
    • Start by holding your Sony Clie PEG-SL10 face-up in your hand.
  2. Disassembling Sony Clie PEG-SL10: paso 2, imagen 1 de 1
    • Turn over your Sony Clie and unlock the cover slide lock.
  3. Disassembling Sony Clie PEG-SL10: paso 3, imagen 1 de 1
    • After unlocking the cover slide lock, remove the cover and set aside.
  4. Disassembling Sony Clie PEG-SL10: paso 4, imagen 1 de 1
    • Turn your Sony Clie face-up.
    • Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
  5. Disassembling Sony Clie PEG-SL10: paso 5, imagen 1 de 1
    • Remove the front case by gently lifting away from the device.
  6. Disassembling Sony Clie PEG-SL10: paso 6, imagen 1 de 1
    • Turn the Sony Clie face down and open the back case by prying open the left side of the device.
    • It will open like a book connected by hinges on the right side.
  7. Disassembling Sony Clie PEG-SL10: paso 7, imagen 1 de 1
    • Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
  8. Disassembling Sony Clie PEG-SL10: paso 8, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
  9. Disassembling Sony Clie PEG-SL10: paso 9, imagen 1 de 1
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  10. Disassembling Sony Clie PEG-SL10: paso 10, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
  11. Disassembling Sony Clie PEG-SL10: paso 11, imagen 1 de 1
    • Pull the power cable from the socket located above the upper right side of the battery harness.
  12. Disassembling Sony Clie PEG-SL10: paso 12, imagen 1 de 1
    • Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
  13. Disassembling Sony Clie PEG-SL10: paso 13, imagen 1 de 1
    • Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
  14. Disassembling Sony Clie PEG-SL10: paso 14, imagen 1 de 1
    • Gently pull out the clips to remove the top power cables from the motherboard.
Conclusión
Documentos Adjuntos
Steve
Miembro Desde 10/18/11
9 Reputación
1 Guía escrita
Equipo
James Madison, Team 1-4, Allen Fall 2011 Miembro de James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,727
