Saltar al contenido principal
Disassembling Sanyo VPC-T850 Outer Casing
Qué necesitas
  1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: paso 1, imagen 1 de 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: paso 2, imagen 1 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: paso 2, imagen 2 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: paso 2, imagen 3 de 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: paso 3, imagen 1 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: paso 3, imagen 2 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: paso 3, imagen 3 de 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Disassembling Sanyo VPC-T850 Outer Casing: paso 4, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Disassembling Sanyo VPC-T850 Outer Casing: paso 5, imagen 1 de 1
    • Separate the rear panel from the rest of the camera.
  6. Disassembling Sanyo VPC-T850 Outer Casing: paso 6, imagen 1 de 2 Disassembling Sanyo VPC-T850 Outer Casing: paso 6, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Disassembling Sanyo VPC-T850 Outer Casing: paso 7, imagen 1 de 2 Disassembling Sanyo VPC-T850 Outer Casing: paso 7, imagen 2 de 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: paso 8, imagen 1 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: paso 8, imagen 2 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: paso 8, imagen 3 de 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
Conclusión
Jonathan Yau
Miembro Desde 04/11/10
26 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 27-95, Amido Spring 2010 Miembro de Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,053
