Saltar al contenido principal
Dell G3 3590 (2019) Hard Drive Replacement
Qué necesitas
  1. Dell G3 3590 (2019) Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Shut down the laptop.
  2. Dell G3 3590 (2019) Hard Drive Replacement: paso 2, imagen 1 de 2 Dell G3 3590 (2019) Hard Drive Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to loosen the four captive screws in the bottom cover.
    • The captive screws will not come out. If you keep loosening the captive screws and hear clicks, then they are loosened enough.
    • Remove six silver 7 mm screws using a Phillips #00 screwdriver.
  3. Dell G3 3590 (2019) Hard Drive Replacement: paso 3, imagen 1 de 2 Dell G3 3590 (2019) Hard Drive Replacement: paso 3, imagen 2 de 2
    • Use the opening tool to pry the base cover from the laptop.
    • Lift the base cover off.
  4. Dell G3 3590 (2019) Hard Drive Replacement: paso 4, imagen 1 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 4, imagen 2 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 4, imagen 3 de 3
    • Disconnect the battery cable from the system board.
    • Disconnecting the battery cable will require some gentle wiggling.
  5. Dell G3 3590 (2019) Hard Drive Replacement: paso 5, imagen 1 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 5, imagen 2 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 5, imagen 3 de 3
    • Open the latch.
    • Disconnect the hard drive cable from the system board.
    • The latch does not need the opening tool to open. You can use your fingernail.
  6. Dell G3 3590 (2019) Hard Drive Replacement: paso 6, imagen 1 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 6, imagen 2 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove three black 3 mm screws.
    • Lift the hard drive assembly to remove it from the laptop.
  7. Dell G3 3590 (2019) Hard Drive Replacement: paso 7, imagen 1 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 7, imagen 2 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 7, imagen 3 de 3
    • Gently pull the interposer from the hard drive.
    • Removing the interposer will require some work. Alternate pulling on one side, then the other until the interposer comes out.
  8. Dell G3 3590 (2019) Hard Drive Replacement: paso 8, imagen 1 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 8, imagen 2 de 3 Dell G3 3590 (2019) Hard Drive Replacement: paso 8, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove four black 3 mm screws from the hard drive bracket.
    • Remove the hard drive from the hard drive bracket.
    • Add the new hard drive into the hard drive bracket.
Conclusión
Once you’ve inserted the new hard drive into the hard drive bracket, reassembling the device can be done by reversing the instructions back to step one. You should hear clicks when you put the base cover back. The clicks ensure that the base cover is secured to the laptop. After this, start up the laptop and ensure it properly starts up.
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 41
Ultimos 30 días: 139
Todo El Tiempo: 3,279
