Saltar al contenido principal
Datawind Ubislate 7ci Speaker Replacement
Qué necesitas
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: paso 1, imagen 1 de 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: paso 2, imagen 1 de 2 Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: paso 2, imagen 2 de 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: paso 3, imagen 1 de 1
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: paso 4, imagen 1 de 1
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: paso 5, imagen 1 de 1
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: paso 6, imagen 1 de 1
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: paso 7, imagen 1 de 2 Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: paso 7, imagen 2 de 2
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
Conclusión
Una persona más ha completado esta guía.
Mekides
Miembro Desde 10/20/14
40 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 286
