Saltar al contenido principal
Datawind Ubislate 7ci Rear Facing Camera Replacement
Qué necesitas
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: paso 1, imagen 1 de 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: paso 2, imagen 1 de 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: paso 2, imagen 2 de 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: paso 3, imagen 1 de 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: paso 3, imagen 2 de 2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: paso 4, imagen 1 de 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: paso 4, imagen 2 de 2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: paso 5, imagen 1 de 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: paso 5, imagen 2 de 2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: paso 6, imagen 1 de 1
    • Press the back cover of the tablet on firmly until it clicks
Conclusión
2 personas más completaron esta guía.
Mekides
Miembro Desde 10/20/14
40 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 291
