Saltar al contenido principal
Datawind Ubislate 7ci Battery Replacement
Qué necesitas
  1. Datawind Ubislate 7ci Battery Replacement, Battery: paso 1, imagen 1 de 2 Datawind Ubislate 7ci Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: paso 2, imagen 1 de 3 Datawind Ubislate 7ci Battery Replacement: paso 2, imagen 2 de 3 Datawind Ubislate 7ci Battery Replacement: paso 2, imagen 3 de 3
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: paso 3, imagen 1 de 3 Datawind Ubislate 7ci Battery Replacement: paso 3, imagen 2 de 3 Datawind Ubislate 7ci Battery Replacement: paso 3, imagen 3 de 3
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: paso 4, imagen 1 de 2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: paso 4, imagen 2 de 2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: paso 5, imagen 1 de 2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: paso 5, imagen 2 de 2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
Conclusión
6 personas más completaron esta guía.
Mekides
Miembro Desde 10/20/14
40 Reputación
3 Guías creadas
Equipo
2 comentarios
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Contestar
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 9,032
