Saltar al contenido principal
Cupboard Drawer handle Replacement
Qué necesitas
  1. Cupboard Drawer handle Replacement, Handle: paso 1, imagen 1 de 1
    • Remove the drawer from the cupboard and empty the contents.
  2. Cupboard Drawer handle Replacement: paso 2, imagen 1 de 1
    • Tighten the good side of the handle by rotating the screwdriver in a clockwise direction.
  3. Cupboard Drawer handle Replacement: paso 3, imagen 1 de 3 Cupboard Drawer handle Replacement: paso 3, imagen 2 de 3 Cupboard Drawer handle Replacement: paso 3, imagen 3 de 3
    • Take a screw with a similar radius of the handle’s hole for the drawer.
  4. Cupboard Drawer handle Replacement: paso 4, imagen 1 de 3 Cupboard Drawer handle Replacement: paso 4, imagen 2 de 3 Cupboard Drawer handle Replacement: paso 4, imagen 3 de 3
    • Line up the hole or holes on the back of the handle with the holes in the front plate of the drawer.
    • Take the screw and insert it in the hole at the back of the drawer.
  5. Cupboard Drawer handle Replacement: paso 5, imagen 1 de 3 Cupboard Drawer handle Replacement: paso 5, imagen 2 de 3 Cupboard Drawer handle Replacement: paso 5, imagen 3 de 3
    • Adjust the screw in a way that it stays in a straight line.
    • Slowly rotate the screw clockwise and in a straight position so that the handle stays erect.
  6. Cupboard Drawer handle Replacement: paso 6, imagen 1 de 2 Cupboard Drawer handle Replacement: paso 6, imagen 2 de 2
    • Make sure to check the grip of the handle.
Conclusión
Una persona más ha completado esta guía.
Raisa Jahan
Miembro Desde 07/06/21
160 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 509
