Saltar al contenido principal
Crown Range Hood AFG-AC/SS Light Bulb Replacement
Qué necesitas
  1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: paso 1, imagen 1 de 1
    • Check to make sure the the range hood is off.
    • To turn the range hood off, press the highlighted button.
    • The range hood should not emit any light or make any noise.
  2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 2, imagen 1 de 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
    • Too prevent both of the items from falling, hold onto the screw and panel during removal.
  3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 3, imagen 1 de 1
    • Slide the lightbulb cover out from the recessed area under the hood.
  4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 4, imagen 1 de 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 4, imagen 2 de 2
    • Twist the light bulb left to remove it from the range hood.
  5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 5, imagen 1 de 1
    • Use a cloth or a paper towel to clean the inside of the light bulb area.
    • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
  6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 6, imagen 1 de 1
    • Guide the new lightbulb to the middle of the lightbulb base.
    • Install the new lightbulb with a twisting motion to the right.
    • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
  7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 7, imagen 1 de 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 7, imagen 2 de 2
    • Place the screw back into the light bulb cover.
  8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 8, imagen 1 de 1
    • Set the light bulb cover back onto the light recess.
    • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
  9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: paso 9, imagen 1 de 1
    • Turn the light on to make sure your repair was successful!
Linea de Meta
Ken Cantago
Miembro Desde 01/30/23
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 33
Todo El Tiempo: 411
