Saltar al contenido principal
Cracked Grout Replacement
Qué necesitas
  1. Cracked Grout Replacement, Cracked Grout: paso 1, imagen 1 de 2 Cracked Grout Replacement, Cracked Grout: paso 1, imagen 2 de 2
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: paso 2, imagen 1 de 1
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: paso 3, imagen 1 de 2 Cracked Grout Replacement: paso 3, imagen 2 de 2
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: paso 4, imagen 1 de 2 Cracked Grout Replacement: paso 4, imagen 2 de 2
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: paso 5, imagen 1 de 1
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: paso 6, imagen 1 de 3 Cracked Grout Replacement: paso 6, imagen 2 de 3 Cracked Grout Replacement: paso 6, imagen 3 de 3
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: paso 7, imagen 1 de 3 Cracked Grout Replacement: paso 7, imagen 2 de 3 Cracked Grout Replacement: paso 7, imagen 3 de 3
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: paso 8, imagen 1 de 2 Cracked Grout Replacement: paso 8, imagen 2 de 2
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: paso 9, imagen 1 de 1
    • Your new grout is dry and ready for use.
Conclusión
To repair any other cracks in grout, repeat these steps.
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 34
Ultimos 30 días: 193
Todo El Tiempo: 3,733
