Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Video Camera, utiliza nuestros manuales de servicio .
  1. Canary  Connect (Home Internet Security Camera), Cracking Open the Case: paso 1, imagen 1 de 2 Canary  Connect (Home Internet Security Camera), Cracking Open the Case: paso 1, imagen 2 de 2
    • The key to cracking open Canary is in the base. First pop off the rubber foot, and remove four screws.
    • Canary uses multiple screw types. If you ever hope to get it back together, consider a screw management system (here plastic bags for each section of the disassembly).
    • Once you get the base off, you'll need to peel off the front plate (held on with double sticky tape).
  2. Canary  Connect (Home Internet Security Camera), Dissecting the Base: paso 2, imagen 1 de 3 Canary  Connect (Home Internet Security Camera), Dissecting the Base: paso 2, imagen 2 de 3 Canary  Connect (Home Internet Security Camera), Dissecting the Base: paso 2, imagen 3 de 3
    • The base does not do all that much. It holds Ethernet, audio jack, and USB power plugs, along with a steel plate for heft.
    • Note the attention to detail: there's a second PCB board for no apparent purpose other than making the audio jack line up with the USB jack. That's obsession!
    • The little chimney is, in fact, a chimney. The idea is that hot air from the electronics rises, drawing room air. This is an older approach (see grated US patent http://patents.justia.com/patent/6347747 ).
  3. Canary  Connect (Home Internet Security Camera), Heat Sinks: paso 3, imagen 1 de 3 Canary  Connect (Home Internet Security Camera), Heat Sinks: paso 3, imagen 2 de 3 Canary  Connect (Home Internet Security Camera), Heat Sinks: paso 3, imagen 3 de 3
    • The inside is dominated by a aluminum plate with dimples for the Ambarella A5S CPU and the back of the image sensor. The heat sink presses against the outer case, through a squishy thermal interface material (TIM).
    • The huge round thing is a buzzer. The round PCB board hosts the 2.4Ghz WiFi and bluetooth antennas (there is no 5Ghz).
    • The infrared LED board sports a plastic frame to aim each LED separately.
  4. Canary  Connect (Home Internet Security Camera), What's Behind the Lens?: paso 4, imagen 1 de 2 Canary  Connect (Home Internet Security Camera), What's Behind the Lens?: paso 4, imagen 2 de 2
    • Canary achieves its flat lens front with an extra sheet of glass that's not optically active. Buried inside is a conventionally shaped M12 security lens.
    • A switchable IR blocking filter is included for day/night mode. This blocks IR light during the day, but switches to be transparent at night.
    • The lens holder is unremarkable. Components are placed within the light chamber to allow the back to support the heat sink.
    • Note the empty holes for... some sort of sensor, not stuffed. Maybe air quality?
    • That's it. I hope you've enjoyed this tour into the insides of Canary.
Bryce Nesbitt
Miembro Desde 11/30/14
1,023 Reputación
9 Guías creadas
3 comentarios
Hi there! What do they use measure air quality? In fact what is air quality for Canary - CO2 or something else?
Gary - Contestar
Would like to know WiFi module model? Artheros?
Chihwei Lu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 37
Todo El Tiempo: 6,083
