Saltar al contenido principal
Cabinet Door Hinge Replacement
Qué necesitas
  1. Cabinet Door Hinge Replacement, Hinge: paso 1, imagen 1 de 1
    • Remove the old screws to take the hinge off.
  2. Cabinet Door Hinge Replacement: paso 2, imagen 1 de 3 Cabinet Door Hinge Replacement: paso 2, imagen 2 de 3 Cabinet Door Hinge Replacement: paso 2, imagen 3 de 3
    • Take the hinge off the cabinet door.
  3. Cabinet Door Hinge Replacement: paso 3, imagen 1 de 1
    • Align the new hinge on the cabinet so that it is even and level and will open and close correctly.
  4. Cabinet Door Hinge Replacement: paso 4, imagen 1 de 2 Cabinet Door Hinge Replacement: paso 4, imagen 2 de 2
    • Insert and screw in the screw closest to the inside of the cabinet.
    • The innermost screw should be fastened first because it's the hardest to get to once the other screws are placed.
    • Screw in the rest of the screws until the hinge is in place.
  5. Cabinet Door Hinge Replacement: paso 5, imagen 1 de 1
    • The hinge is now replaced and the cabinet can shut all the way.
Linea de Meta
McKenna Harris
Miembro Desde 10/23/20
121 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S9-G4, Cowan Fall 2020 Miembro de Texas Tech, Team S9-G4, Cowan Fall 2020
TTU-COWAN-F20S9G4
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 32
Todo El Tiempo: 569
