Saltar al contenido principal
Cabinet Door Butt Hinge Replacement
Qué necesitas
  1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: paso 1, imagen 1 de 1
    • Determine where the cabinet needs repair: on the top or bottom hinge.
  2. Cabinet Door Butt Hinge Replacement: paso 2, imagen 1 de 1
    • Measure the hinge to make sure you have the correct size of your butt hinge.
    • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
  3. Cabinet Door Butt Hinge Replacement: paso 3, imagen 1 de 1
    • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
    • Keep the screws nearby; you will need them later.
  4. Cabinet Door Butt Hinge Replacement: paso 4, imagen 1 de 1
    • Align the cabinet door to stand straight with any surrounding cabinets.
  5. Cabinet Door Butt Hinge Replacement: paso 5, imagen 1 de 1
    • Place the new hinge where the previous one was. Align the holes together.
  6. Cabinet Door Butt Hinge Replacement: paso 6, imagen 1 de 1
    • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
Conclusión
If the door closes parallel to any surrounding cabinets, your fix is complete!
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 53
Todo El Tiempo: 237
