Saltar al contenido principal
Buick Key Fob Battery Replacement
Qué necesitas
  1. Buick Key Fob Battery Replacement, Remove the Inner Key: paso 1, imagen 1 de 1
    • Push the chrome button on the back of the key fob to release the inner key
  2. Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: paso 2, imagen 1 de 2 Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: paso 2, imagen 2 de 2
    • Using an opening tool/pick helps avoid damage, however you can also use the inner key to pry the two shells apart
    • If using the inner key to pry them apart, just reinsert the tip of the key into fob and gently twist
  3. Buick Key Fob Battery Replacement, Remove Old Battery: paso 3, imagen 1 de 1
    • Slide a tool underneath the old battery to pop it out, the replacement battery goes in face down toward the bottom shell
Conclusión
Una persona más ha completado esta guía.
Jim
Miembro Desde 06/17/23
331 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 54
Todo El Tiempo: 671
