Saltar al contenido principal
Bomann DB 774CB Iron
Qué necesitas
  1. Bomann DB 774CB Iron, Startup: paso 1, imagen 1 de 1
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: paso 2, imagen 1 de 3 Bomann DB 774CB Iron, Undressing the handle: paso 2, imagen 2 de 3 Bomann DB 774CB Iron, Undressing the handle: paso 2, imagen 3 de 3
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: paso 3, imagen 1 de 2 Bomann DB 774CB Iron, Stripping of the sole: paso 3, imagen 2 de 2
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: paso 4, imagen 1 de 1
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
Conclusión
Putting each screw back in its place is no problem.
6 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Louis Possoz
Miembro Desde 01/10/15
435 Reputación
3 Guías creadas
Equipo
Repair Café Louvain-la-Neuve Miembro de Repair Café Louvain-la-Neuve
Local Repair Groups
2 Miembros
6 Guías creadas
Un comentario
Do you instructions in English
Nur Haque - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 48
Todo El Tiempo: 2,981
