Saltar al contenido principal
Bell and Howell DNV16HDZ LED Replacement
Qué necesitas
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: paso 1, imagen 1 de 2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: paso 1, imagen 2 de 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: paso 3, imagen 1 de 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: paso 4, imagen 1 de 1
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: paso 5, imagen 1 de 3 Bell and Howell DNV16HDZ LED Replacement: paso 5, imagen 2 de 3 Bell and Howell DNV16HDZ LED Replacement: paso 5, imagen 3 de 3
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Conclusión
Donald Desrosier
Miembro Desde 03/11/16
101 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Miembro de UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 303
