Saltar al contenido principal
Back Case
Qué necesitas
  1. Back Case, Battery: paso 1, imagen 1 de 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Back Case: paso 2, imagen 1 de 3 Back Case: paso 2, imagen 2 de 3 Back Case: paso 2, imagen 3 de 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Back Case: paso 3, imagen 1 de 2 Back Case: paso 3, imagen 2 de 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Back Case, Back Case: paso 4, imagen 1 de 1
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Back Case: paso 5, imagen 1 de 1
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Back Case: paso 6, imagen 1 de 2 Back Case: paso 6, imagen 2 de 2
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Back Case: paso 7, imagen 1 de 1
    • Remove face plate.
  8. Back Case: paso 8, imagen 1 de 3 Back Case: paso 8, imagen 2 de 3 Back Case: paso 8, imagen 3 de 3
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Back Case: paso 9, imagen 1 de 3 Back Case: paso 9, imagen 2 de 3 Back Case: paso 9, imagen 3 de 3
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Back Case: paso 10, imagen 1 de 2 Back Case: paso 10, imagen 2 de 2
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Back Case: paso 11, imagen 1 de 3 Back Case: paso 11, imagen 2 de 3 Back Case: paso 11, imagen 3 de 3
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
Conclusión
Larissa Knight
Miembro Desde 03/21/16
549 Reputación
5 Guías creadas
Equipo
Clemson, Team 7-2, Benson Spring 2016 Miembro de Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 706
