Saltar al contenido principal
Accessing LCD Screen
Qué necesitas
  1. Accessing LCD Screen, Front and Back Cover: paso 1, imagen 1 de 2 Accessing LCD Screen, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Accessing LCD Screen: paso 2, imagen 1 de 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Accessing LCD Screen: paso 3, imagen 1 de 2 Accessing LCD Screen: paso 3, imagen 2 de 2
    • Carefully pull the back of casing away from the front.
  4. Accessing LCD Screen: paso 4, imagen 1 de 3 Accessing LCD Screen: paso 4, imagen 2 de 3 Accessing LCD Screen: paso 4, imagen 3 de 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Accessing LCD Screen: paso 5, imagen 1 de 2 Accessing LCD Screen: paso 5, imagen 2 de 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Accessing LCD Screen, LCD: paso 6, imagen 1 de 2 Accessing LCD Screen, LCD: paso 6, imagen 2 de 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Accessing LCD Screen: paso 7, imagen 1 de 2 Accessing LCD Screen: paso 7, imagen 2 de 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
  8. Accessing LCD Screen: paso 8, imagen 1 de 1
    • Pull the cover plate off for the two power cord jacks.
  9. Accessing LCD Screen: paso 9, imagen 1 de 3 Accessing LCD Screen: paso 9, imagen 2 de 3 Accessing LCD Screen: paso 9, imagen 3 de 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Accessing LCD Screen: paso 10, imagen 1 de 1
    • Remove the orange tape on top of the SD cardholder.
  11. Accessing LCD Screen: paso 11, imagen 1 de 3 Accessing LCD Screen: paso 11, imagen 2 de 3 Accessing LCD Screen: paso 11, imagen 3 de 3
    • Open the battery cover and lift plastic piece off.
  12. Accessing LCD Screen: paso 12, imagen 1 de 1
    • Remove tape on left side of camera.
  13. Accessing LCD Screen: paso 13, imagen 1 de 1
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
  14. Accessing LCD Screen: paso 14, imagen 1 de 1
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
  15. Accessing LCD Screen: paso 15, imagen 1 de 2 Accessing LCD Screen: paso 15, imagen 2 de 2
    • Push down bottom left LCD bracket to release the LCD from grip.
  16. Accessing LCD Screen: paso 16, imagen 1 de 1
    • Gently lift up LCD screen.
  17. Accessing LCD Screen: paso 17, imagen 1 de 3 Accessing LCD Screen: paso 17, imagen 2 de 3 Accessing LCD Screen: paso 17, imagen 3 de 3
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
Conclusión
Bassem Tossoun
Miembro Desde 01/21/11
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-29, Regan Winter 2011 Miembro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 1,040
