Saltar al contenido principal
AKG Y50BT/C50BT Battery Replacement
  1. AKG Y50BT/C50BT Battery Replacement, Tools & Parts Used: paso 1, imagen 1 de 1
  2. AKG Y50BT/C50BT Battery Replacement, Remove (L) Ear Pad: paso 2, imagen 1 de 2 AKG Y50BT/C50BT Battery Replacement, Remove (L) Ear Pad: paso 2, imagen 2 de 2
    • Remove the left (L) ear pad by rotating it counter clockwise and it will be removed
  3. AKG Y50BT/C50BT Battery Replacement, Unscrew Cover: paso 3, imagen 1 de 1
    • Remove the four screws using a Philips screwdriver
  4. AKG Y50BT/C50BT Battery Replacement, Remove Cover: paso 4, imagen 1 de 2 AKG Y50BT/C50BT Battery Replacement, Remove Cover: paso 4, imagen 2 de 2
    • Turn it upside down and remove the AKG cover. This will expose the battery
  5. AKG Y50BT/C50BT Battery Replacement, (Optional): paso 5, imagen 1 de 1
    • Confirm the replacement battery has the wires in the correct orientation (Red / Black / Traveller). If not, pry the connector and remove pin and replace in correct position
  6. AKG Y50BT/C50BT Battery Replacement, Remove Battery Connector: paso 6, imagen 1 de 1
    • Remove pin connector by prying back the connector. Tip - use a tweezer
    • Connect the replacement battery to ensure it works
  7. AKG Y50BT/C50BT Battery Replacement, Remove Battery: paso 7, imagen 1 de 1
    • The battery is adhered with double sided tape. Carefully remove the battery by using a tool to pry out the tape, i.e. X-Acto knife
    • Remove the residue by using rubbing alcohol
  8. AKG Y50BT/C50BT Battery Replacement, Replace Battery: paso 8, imagen 1 de 2 AKG Y50BT/C50BT Battery Replacement, Replace Battery: paso 8, imagen 2 de 2
    • Insert double-sided tape
    • Place the battery in an orientation that does not block the screw holes for the cover
Conclusión
5 personas más completaron esta guía.
Kevin
Miembro Desde 03/06/17
307 Reputación
1 Guía escrita
5 comentarios
Very clear directions with excellent photo accompaniment. Battery shown is not the 1500 mAh recommended by manufacturer.
D Hamilton - Contestar
Is ist possible to get a Link for the korrekt Battery
Foto and Instruktion very good!!
Klaus Möller - Contestar
I have linked it in the instructions but here it is, https://www.amazon.ca/gp/product/B07K1J4.... The key is to find a battery that fits the headset.
Remember to reorient the wires, Step 5. For this battery, I had to swap the yellow and black wires.
Kevin -
Great, thanks Kevin!
For the other not so terribly handy fortune-hunters out there, here's another instruction to Step 5:
To remove the 2 wires from the connector in order to swap them, with a thin/sharp cutter/knife/needle you can carefully move up a little the plastic parts of the connector that cover and block the ends of the wires, and then pull out the wires, then push the plastic parts back down, and then push the wires back in correctly.
Steve Rynders - Contestar
Bought a replacement battery. Didn't work so replaced my old battery which, surprisingly, charged up (for a couple of months) and then died. Went back to the replacement, realised the wires were not in correct places. Read this, swapped two over and now working fine.
Thank you so much!
Grace Davidson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 58
Ultimos 30 días: 254
Todo El Tiempo: 4,043
