Saltar al contenido principal
2017 Kia Niro Headlight Replacement
Qué necesitas
  1. 2017 Kia Niro Headlight Replacement, Headlight: paso 1, imagen 1 de 1
    • Open the hood of the vehicle and make sure it is secured to prevent injury.
  2. 2017 Kia Niro Headlight Replacement: paso 2, imagen 1 de 1
    • Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
  3. 2017 Kia Niro Headlight Replacement: paso 3, imagen 1 de 1
    • Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
  4. 2017 Kia Niro Headlight Replacement: paso 4, imagen 1 de 1
    • Place the cap in a location that is out of the way of your work area and where you can easily find it.
  5. 2017 Kia Niro Headlight Replacement: paso 5, imagen 1 de 1
    • Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
  6. 2017 Kia Niro Headlight Replacement: paso 6, imagen 1 de 1
    • Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
  7. 2017 Kia Niro Headlight Replacement: paso 7, imagen 1 de 1
    • Insert the new bulb by pushing it into the bulb compartment.
    • Turn the bulb clockwise until it is secure.
  8. 2017 Kia Niro Headlight Replacement: paso 8, imagen 1 de 1
    • Reattach the cap you previously set aside by rotating clockwise until secure.
Linea de Meta
3 personas más completaron esta guía.
Sydney Harper
Miembro Desde 10/23/20
229 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S9-G6, Cowan Fall 2020 Miembro de Texas Tech, Team S9-G6, Cowan Fall 2020
TTU-COWAN-F20S9G6
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 24
Ultimos 30 días: 121
Todo El Tiempo: 3,828
