Introducción
In this guide, we show and explain how to access the spark plugs, and how to swap them and reassemble the car once it's done. The illustrations are of a 5.7 liter V8 motor, but the same steps can be applied to a V6 of the same year.
Qué necesitas
Unlatch and lift the hood of your car.
Locate the coil packs covering the spark plugs.
Before installing new spark plugs, use a gap gauge to measure the gap at the bottom of the spark plug.
Once you have checked the gap of the spark plug it can be installed. Then swap the ratchet to tighten and use it with the extension and 5/8 spark plug socket to install the new spark plugs.
Congratulations, you have successfully replaced the spark plugs of a 2016 Dodge Charger.
Keep in mind that it is recommended by manufacturer to change them every 30000 miles. By using this guide to change them yourself you will save roughly 200 dollars versus going to an auto repair shop.
Un comentario
Thank you for your information and pictures but this is not for all of them and the left side of engine is way harder than right side please include that as well!
