Saltar al contenido principal
2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement
Qué necesitas
  1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: paso 1, imagen 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: paso 1, imagen 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: paso 1, imagen 3 de 3
    • Start by pressing down on the button that opens the center arm-rest.
    • Pop each side of the silver trim using the trim removal tool or a plastic opening tool.
    • Remove the silver trim.
  2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 2, imagen 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 2, imagen 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 2, imagen 3 de 3
    • Remove the two 20 mm screws securing the center console with a T20 Torx screwdriver.
  3. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 3, imagen 1 de 2 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 3, imagen 2 de 2
    • Make sure there aren't any loose articles in the center storage compartment.
    • Lift the end of the center-console and flip it to reveal the undercarriage of the center-dial touchpad and its wirings.
  4. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 4, imagen 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 4, imagen 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 4, imagen 3 de 3
    • Press your thumb on the safety tab to remove each blue connection.
  5. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 5, imagen 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 5, imagen 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 5, imagen 3 de 3
    • Press down on the center of the white connection in the middle and slide the safety latch to the left to pull out the main white connection.
  6. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 6, imagen 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 6, imagen 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: paso 6, imagen 3 de 3
    • Remove the two 15 mm T15 Torx screws holding the center-dial touchpad.
    • Firmly press the center-dial touchpad out to remove the unit.
Conclusión
4 personas más completaron esta guía.
Amin Fadhil
Miembro Desde 09/19/20
243 Reputación
1 Guía escrita
Equipo
Un comentario
This is great thanks, made an account to say thank you
Nolan Scott - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 47
Ultimos 30 días: 181
Todo El Tiempo: 11,170
