Saltar al contenido principal
2013 Subaru Impreza WRX Mud Flaps Replacement
Qué necesitas
  1. 2013 Subaru Impreza WRX Mud Flaps Replacement, Mud Flaps: paso 1, imagen 1 de 1
    • Always make sure your car is off, the parking break is applied, and you are in a safe area free from other passing cars.
  2. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 2, imagen 1 de 1
    • Turn the wheels all the way towards the side you will be working on.
    • This will create easier access to the inside of the wheel well when you are replacing the mud flap.
  3. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 3, imagen 1 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 3, imagen 2 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 3, imagen 3 de 3
    • Start with the front mud flaps.
    • Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
  4. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 4, imagen 1 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 4, imagen 2 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 4, imagen 3 de 3
    • Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
    • Be careful not to loose the rubber gasket attached to the screw.
  5. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 5, imagen 1 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 5, imagen 2 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 5, imagen 3 de 3
    • Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
    • Repeat for opposite front mud flap.
  6. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 6, imagen 1 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 6, imagen 2 de 3 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 6, imagen 3 de 3
    • For the back two mud flaps you will need to use a slightly different technique due to the limited space you will be working in.
    • Use your hands and the 10mm wrench piece to unbolt the mud flap.
    • Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
    • This step will be aided by the use of an extra small Philips screwdriver.
  7. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 7, imagen 1 de 2 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 7, imagen 2 de 2
    • Replace both back mud flaps and fasten all pieces back in place.
  8. 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 8, imagen 1 de 2 2013 Subaru Impreza WRX Mud Flaps Replacement: paso 8, imagen 2 de 2
    • Make sure the mud flaps are all properly tightened and positioned before driving your car again.
    • Enjoy your brand new mud flaps.
Conclusión
Alex Davis
Miembro Desde 09/29/15
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-3, Green Fall 2015 Miembro de Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 951
