Saltar al contenido principal
2012-2018 Nissan Versa Note Headlight Bulb Replacement
Qué necesitas
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 2 de 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 2, imagen 1 de 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 3, imagen 1 de 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 4, imagen 1 de 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 5, imagen 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 5, imagen 2 de 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 6, imagen 1 de 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 7, imagen 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 7, imagen 2 de 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 8, imagen 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 8, imagen 2 de 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 9, imagen 1 de 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 10, imagen 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: paso 10, imagen 2 de 2
    • Insert the connector into the bulb.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 50
Ultimos 30 días: 257
Todo El Tiempo: 12,450
