Saltar al contenido principal
2010 Mazda 5 How to Troubleshoot Oxygen Sensor
Qué necesitas
  1. 2010 Mazda 5 How to Troubleshoot Oxygen Sensor, Fuse box check: paso 1, imagen 1 de 1
    • Check the fuse for the pre-heating of the oxygen sensor (in this case #37)
  2. 2010 Mazda 5 How to Troubleshoot Oxygen Sensor, Enummerate pins: paso 2, imagen 1 de 1
    • Unplug the sensor and decide on a numbering scheme. Also clean the pins to ensure this is not a connection problem
  3. 2010 Mazda 5 How to Troubleshoot Oxygen Sensor, Meassure: paso 3, imagen 1 de 1
    • Check all combinations of the pins of problematic sensor. See comparison chart above (with the new replacement sensor).
    • If you do not have such a tester, a normal multimeter (resistance and capacitance) should be sufficient
    • If you would like a transistor tester, you can search Aliexpress for one. It is an amasing little device. https://www.aliexpress.com/item/10050015...
Conclusión
Leasson learned: probe the oxygen sensor pins if you experience problems:
  • Pin 1-2 is the pre-heating element, and should show around 5-6 Ohm (meaning that the pre-heating must be using around 60W)
  • All other combinations of pins should show a capacitance around 50 pF
There is a clear difference in the meassurements when comparing the defect part and the new replacement part.
Here are some good resources on Mazda and oxygen sensors, but remember: meassure the pins and look for signs of a defect device before you start taking tings apart
https://www.youtube.com/watch?v=jFFR4307...
https://www.youtube.com/watch?v=XC5HWd7P...
https://www.youtube.com/watch?v=fiOxH14J...
https://www.700r4transmissionhq.com/p013...
LarsWH
Miembro Desde 03/05/16
887 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 26
Ultimos 30 días: 84
Todo El Tiempo: 1,391
